Other AMR AMR-WB Parameters
AMR/AMR-WB support the following additional optional parameters. These parameters are irrelevant in the transcoding decision process. However, they can change the SDP in the answer returned to the session initiator.
channels mode-change-neighbor crc mode-change-period interleaving mode-set max-red octet-align maxtime ptime mode-change-capability robust-sorting
