Restricted Latching Configuration
To configure restricted latching:
In Superuser mode, type
configure terminal and press Enter.
ORACLE# configure terminal
Type
media-manager and press Enter to access the media-level configuration elements.
ORACLE(configure)# media-manager ORACLE(media-manager)#
Type
realm-config and press Enter. The system prompt changes to let you know that you can begin configuring individual parameters.
ORACLE(media-manager)# realm-config ORACLE(realm-config)#
Select the realm where you want to apply this feature.
ORACLE(realm-config)# select identifier: 1: Acme_Realm <none> 0.0.0.0 2: H323REALM <none> 0.0.0.0 selection:1 ORACLE(realm-config)#
restricted-latching— Enter the restricted latching mode. The default is
none. The valid values are:
none—No restricted-latching used
sdp—Use the address provided in the SDP for latching
peer-ip—Use the layer 3 signaling address for latching
restriction-mask— Enter the number of address bits you want used for the source latched address. This field will be used only if the restricted-latching is used. The default is 32. When this value is used, the complete IP address is matched for IPv4 addresses. The valid range is:
Minimum—1
Maximum—128
