Flow-status AVP
The Flow-status AVP (511) is based on SDP direction. Tests for SDP are performed in the following order:
SDP State Flow-Status AVP (511) Set to
port in the SDP m-line is 0 REMOVED (4)
Transport in m-line is "TCP" or " TCP/MSRP" ENABLED (2)
a=recvonly and <SDP direction> = UE originated ENABLED-DOWNLINK (1)
a=recvonly and <SDP direction> = UE terminated ENABLED-UPLINK (0)
a=sendonly and <SDP direction> = UE originated ENABLED-UPLINK (0)
a=sendonly and <SDP direction> = UE terminated ENABLED-DOWNLINK (1)
a=inactive DISABLED (3)
a=sendrecv or no direction attribute ENABLED (2)
UE originated - Call originator creates the SDP being considered.
UE terminated - Call terminator creates the SDP being considered.
Flow-status AVP is always created according and requires no configuration.
