Specific Reason Headers in 503 Response
The Oracle Communications Session Border Controller issues a 503 Service Unavailable SIP response code when it fails to fulfill an apparently valid request because it is undergoing maintenance or is temporarily overloaded and so cannot process the request. This feature changes the reason phrase in the SIP response from the generic “Service Unavailable” to one that specifies the overload condition when exceeding provisioned session capacity, transcoding sessions, or DSP resources.
The Oracle Communications Session Border Controller sends SIP responses with the values of status-code and sip-reason in the local-response-map-entries configuration element as status text when the provisioned session capacity, transcoding sessions, or DSP resource capacity has reached its maximum limit and the capacity has been noted in the local-error parameter of the local-response-map-entries configuration element. The SBC issues the generic “Service Unavailable” when the capacity has not been noted in the in the local-response-map-entries configuration element. Additionally, this feature adds the values of q.850-cause and q.850-reason in the local-response-map-entries configuration element to the reason header when the value of add-reason header in the sip-config configuration element is enabled.
