PreviousNextJavaScript must be enabled to correctly display this content
NPLI Enabling NPLI Notifications
The P-CSCF sends the PCRF AAR messages containing the Specific-Action and Required-Access-Info AVPs to indicate a desired notification/subscription type. Use the following procedure to request NPLI notifications.
Use the
specific-action-subscription parameter to specify one or more specific actions. When designating 2 or more actions, enclose them in quotation marks, with the values separated by spaces. Use
access-network-info-report to enable NPLI support.
