R226 and SIPREC License Management
Enabling the R226 Certification self-entitlement disables the ability to enable SIPREC through the self-entitlement mechanism.
Once the R226 entitlement is enabled:
- The R226 entitlement cannot be disabled through the self-entitlement mechanism.
- Any previously installed SIPREC entitlement is flushed from the system.
- SIPREC is no longer an
option under the
setup entitlementscommand. - SIPREC can only be enabled with a license key.
To disable the R226 self-entitlement, contact Oracle Support and follow the factory reset instructions in the Admin Security Guide.
