AAR Message Configuration
To optimize the use of AAR messages:
Access the
ext-policy-server configuration element.
ORACLE# configure terminal ORACLE(configure)# media-manager ORACLE(media-manager)# ext-policy-server ORACLE(ext-policy-server)#
Select the
ext-policy-server object to edit.
ORACLE(ext-policy-server)# select <name>:1: name=extpol1 selection: 1 ORACLE(ext-policy-server)#
- optimize-aar—Set this parameter to enabled to optimize the use of AAR messages.
- reserve-incomplete—Set this parameter to enabled in conjunction with optimize-aar set to enabled for the system to not send an AAR to the PCRF if the Proxy-authorization header is absent from the INVITE.
- Type done to save your configuration.
