UAC does not Support Session Timers
If the UAC’s initial request does not include a Session-Expires: header, then the 200 OK will include the session-timer-profile, session-expires value on the ingress leg in the Session-Expires: header.
The Oracle Communications Session Border Controller also inserts the refresher parameter as configured. The orientation of UAC/UAS on the Oracle Communications Session Border Controller’s view of a call leg can change if later in the call flow the endpoint designates the Oracle Communications Session Border Controller as the refresher.
When the request doesn't support Session Timers, the Oracle Communications Session Border Controller’s reply adds session timer support according to configuration.If the Oracle Communications Session Border Controller receives a message with a Require: timer header, and the inbound SIP interface or the final UAS do not support session timers, a 420 (Bed Extension) is returned to the UAC.
