Configuring the SIP Configuration
To configure the SIP configuration:
In Superuser mode, type
configure terminal and press Enter.
ORACLE# configure terminal
Type
session-router and press Enter to access the system-level configuration elements.
ORACLE(configure)# session-router
Type
sip-config and press Enter. The system prompt changes.
ORACLE(session-router)# sip-config ORACLE(sip-config)#
From this point, you can configure SIP configuration parameters. To view all sip-config parameters, enter a ? at the system prompt.
inactive-dynamic-conn—Enter the time in seconds after which the
Oracle Communications Session Border Controller tears down inactive dynamic TCP connections. Inactive is defined as not transporting any traffic. This protects against endpoints establishing TCP/TLS connections and then not sending messages. The default value is 32. The valid range is:
Minimum—0
Maximum—999999999
Setting this parameter to 0 disables this parameter.
Because the Oracle Communications Session Border Controller first establishes a TCP connection, then the TLS connection it waits twice the value entered here after the initiation of a TLS connection before tearing down the connection.
After an endpoint establishes a TCP/TLS connection, it is supposed to keep the connection active by sending messages or by using the NAT interval configuration. Whenever a connection is torn down because of inactivity, a log at the level ERROR is generated.
