IPv6-IPv4 Internetworking
The Oracle Communications Session Border Controller supports the following internetworking environments:
SIP-TLS IPv6 endpoints with SIP-TLS IPv4 endpoints
SIP-TLS IPv6 endpoints with SIP-TLS IPv6 endpoints
SIP-TLS IPv6 endpoints with non-SIP-TLS (unencrypted) IPv4 endpoints
SIP-TLS IPv6 endpoints with non-SIP-TLS (unencrypted) IPv6 endpoints
SIP-TLS IPv4 endpoints with non-SIP-TLS (unencrypted) IPv6 endpoints
Previously delivered TLS functionality, for example, support for certificate extensions, and support for certificate chain processing, is not affected by IPv6-IPv4 internetworking.
TLS SRTP Decryption
The Oracle Communications Session Border Controller enables the unencrypted replication of incoming and outgoing TLS/SRTP packets and delivery of such unencrypted packets to a CRS.
Decrypted packets are forwarded to the CSR as shown below.
Original encrypted packet:
+-----------------------+-------------+-----------+------------+ | Encrypted Payload | SSL | TCP | IP | | | Header | Header | Header | +-----------------------+-------------+-----------+------------+
Replicated unencrypted packet:
+-----------------------+-------------+--------------+-----------+ | Decrypted Payload | UDP | IP | IP | | | Header | Header | Header | | | (original | (original | | | | src/dest | src/dest | | | | ports) | IP addresses | | +-----------------------+-------------+--------------+-----------+
SRTP IPv4 IPv6 Internetworking
Internetworking IPv4 and IPv6 media while using SDES as the key exchange protocol is supported.
SRTP is defined in RFC 3711, The Secure Real-time Transport Protocol (SRTP). It provides confidentiality, message authentication, and replay protection for RTP media and control traffic. SDES is defined in RFC 4568, Session Description Protocol (SDP) Security Descriptions for Media Streams. This RFC describes a new SDP cryptographic attribute that provides a secure method to provide security for unicast media streams.
Supported Topologies
The following internetworking topologies are supported and illustrated below
SRTP IPv4 endpoints with SRTP IPv4 endpoints
SRTP IPv4 endpoints with RTP (unencrypted) IPv6 endpoints
SRTP IPv6 endpoints with SRTP IPv6 endpoints
SRTP IPv6 endpoints with RTP (unencrypted) IPv4 endpoints
SRTP IPv6 endpoints with RTP (unencrypted) IPv6 endpoints
SRTP/SDES IPv4 to SRTP/SDES IPv6 Internetworking
SRTP/SDES IPv4 to RTP IPv6 Internetworking
SRTP/SDES IPv6 to SRTP/SDES IPv6 Internetworking
SRTP/SDES IPv6 to RTP IPv4 Internetworking
SRTP/SDES IPv6 to RTP IPv6 Internetworking
