HIP Addresses
To configure administrative service functionality on a media interface, you must first define all source IP addresses in the media-interface's network that will exchange administrative traffic with the system. Next you will identify the type of administrative traffic each of those addresses will exchange.
You must configure the gateway parameter on this network-interface for administrative traffic to successfully be forwarded. You should also ensure that this network interface is not on an overlapping network as any of the administrative networks (wancoms).
Set the following parameters to configure HIP functionality on a network interface:
  1. add-hip-ip—Configure all possible IP address(es) from which the Oracle Communications Session Border Controller will accept administrative traffic. Entries in this element are IP addresses of media network interfaces. This parameter can accept multiple IP addresses. You can later remove this entry by typing remove-hip-ip followed by the appropriate IP address.
  2. add-ftp-ip—Set the IP address(es) that will access the Oracle Communications Session Border Controller's FTP server. This allows standard FTP packets enter the Oracle Communications Session Border Controller and reach the host. You can later remove this entry by typing remove-ftp-ip followed by the appropriate IP address.
  3. add-icmp-ip—Set the IP address(es) that can ping the system and expect replies. This parameter can accommodate multiple ping IP addresses. You can later remove this entry by typing remove-icmp-ip followed by the appropriate IP address.
    For security, if the ICMP address and the hip-ip-list are not added for an address, the Oracle Communications Session Border Controller hardware discards ICMP requests or responses for the address.
  4. add-snmp-ip—Set the IP address(es) that will access the system's SNMP process. This lets SNMP traffic enter the Oracle Communications Session Border Controller and reach the host. You can later remove this entry by typing remove-snmp-ip followed by the appropriate IP address.
  5. add-telnet-ip—Set the IP address(es) that can connect and access the system through Telnet. You can later remove this entry by typing remove-telnet-ip followed by the appropriate IP address.
  6. add-ssh-ip—Set the IP address(es) that can connect and access the system through SSH. You can later remove this entry by typing remove-SSH-ip followed by the appropriate IP address.
