Configuring RTCP Generation
The procedure below provides the steps needed to configure RTCP generation on the Oracle Communications Session Border Controller.
Before proceeding, make sure you know whether your platform supports transcoding. As described in the section on RTCP generation, this can affect your configuration and operational results.
To have your
Oracle Communications Session Border Controller generate RTCP traffic statistics reporting:
