Basic Scenarios
Examples provided in this section are supported by the following codec policy and media profiles.
codec-policy
name net192
allow-codecs *
add-codecs-on-egress AMR::PT96 AMR-WB::PT97 AMR::PT98
AMR-WB::PT99
order-codecs
force-ptime disabled
packetization-time 30
dtmf-in-audio disabled
media-profile
name AMR
subname PT96
media-type audio
payload-type 96
transport RTP/AVP
req-bandwidth 0
frames-per-packet 0
parameters
average-rate-limit 0
peak-rate-limit 0
max-burst-size 0
sdp-rate-limit-headroom 0
sdp-bandwidth disabled
police-rate 0
standard-pkt-rate 0
media-profile
name AMR-WB
subname PT97
media-type audio
payload-type 97
transport RTP/AVP
req-bandwidth 0
frames-per-packet 0
parameters
peak-rate-limit 0
max-burst-size 0
police-rate 0
standard-pkt-rate 0
media-profile
name AMR
subname PT98
media-type audio
payload-type 98
transport RTP/AVP
req-bandwidth 0
frames-per-packet 0
parameters mode-set="0,1,2,3"
peak-rate-limit 0
max-burst-size 0
police-rate 0
standard-pkt-rate 0
media-profile
name AMR-WB
subname PT99
media-type audio
payload-type 99
transport RTP/AVP
req-bandwidth 0
frames-per-packet 0
peak-rate-limit 0
max-burst-size 0
police-rate 0
standard-pkt-rate 0
The following SDP reflects the case where the session responder answers with the same codec and payload type as presented by the session initiator.
| SDP | Contents |
| Offer received from session initiator |
| Offer sent to responder (per the net192 codec policy) |
| from AMR-WB/PT97 media profile |
| from AMR-WB/PT98 media profile |
| from AMR-WB/PT99 media profile |
| initiator offer |
| Answer received from responder |
| Answer sent to initiator |
| Codecs | Match | Values |
| codec | match | AMR/AMR |
| payload formats | match | bandwidth-efficient (default value) |
| mode-sets | match | inclusive mode-set (0,1,2,3,4,5,6,7) |
| payload mapping | match | 96/96 |
Here, given the identical offer and answer, neither transcoding nor payload type mapping is required.
The following SDP reflects the case where the session responder answers with the codec offered by the session initiator, but with a different payload type.
| SDP | Contents |
| initiator offer |
| codecs | match | AMR/AMR |
| payload mapping | no match | 96/97 |
Here, given the identical offer/answer except for the payload type, transcoding is not required; payload type mapping is used.
The following SDP reflects the case where the session responder answers with a codec not offered by the session initiator.
| SDP | Contents |
| initiator offer |
| codecs | no match | AMR/AMR-WB |
Here, given that the offer and answer codecs (AMR and AMR-WB) are not identical, transcoding is required.
The following SDP reflects the case where the offer specifies the inclusive mode-set, and the answer specifies a non-inclusive mode-set.
| SDP | Contents |
| initiator offer |
| codecs | match | AMR/AMR-WB |
| mode-sets | intersect | (0,1,2,3,4,5,6,7) / (0,1,2,3) |
| payload mapping | no match | 96/98 |
Here, given that the answer mode-set (0,1,2,3) intersects with the offered mode-set (0,1,2,3,4,5,6,7), transcoding is not required; payload type mapping is used.
The following SDP reflects the case where the offer specifies a non-inclusive mode-set, and the answer specifies the inclusive mode-set.
| SDO | Contents |
| from AMR/PT96 media profile |
| initiator offer |
| mode-sets | intersect | (0,1,2,3) / (0,1,2,3,4,5,6,7) |
| payload mapping | no match | 98/96 |
Here, given that the offer mode-set (0,1,2,3) intersects with the answer mode-set (0,1,2,3,4,5,6,7), transcoding is not required; payload type mapping is used.
