IMS Charging Vector Mode Adaptation
This adaptation to the Oracle Communications Session Border Controller’s IMS functionality provides the ability to remove the P-Charging-Vector from incoming requests for a session and store it. Then the Oracle Communications Session Border Controller inserts it into outbound responses related to that session in a P-Charging-Vector header.
IMS Charging Vector Mode Configuration
Typically, the ACLI charging-vector-mode parameter is set to delete-and-respond (which supports removing and storing the P-Charging-Vector for later insertion in outbound response) on the core, trusted interface. On the access, untrusted side, this same parameter is set to insert.
