IR.92 Compliance Configuration
To configure the 380 SIP response for IR.92 compliance:
In Superuser mode, type
configure terminal and press Enter.
ORACLE# configure terminal
Type
session-router and press Enter to access the system-level configuration elements.
ORACLE(configure)# session-router
Type
sip-interface and press Enter. The system prompt changes to let you know that you can begin configuring individual parameters.
ORACLE(session-router)# sip-interface ORACLE(sip-interface)#
From this point, you can configure SIP interface parameters. To view all sip-interface parameters, enter a ? at the system prompt.
- If configuring an existing interface, enter the select command to select the interface.
- send-380-response—Enter a reason phrase enclosed in quotes to place in the reason tag of the <ims-3gpp> element in a 380 response for a failed-to-route emergency call.
- Type done and continue.
