PreviousNextJavaScript must be enabled to correctly display this content
NPLI Emergency Call Configuration
Use this procedure to buffer emergency INVITES pending the receipt of NPLI from the PCRF. This procedure is required for users subject to German telecommunications regulations. For other users, the procedure is optional.
hold-emergency-calls-for-loc-info—Use this parameter to both enable the buffering of emergency INVITES (thus complying with German regulations), and to specify the time (in seconds) that INVITES are buffered.
By default
hold-emergency-calls-for-loc-info is set to the value 0, which disables the buffering of emergency INVITEs.
Set
hold-emergency-calls-for-loc-info to a non-zero value, within the boundaries acceptable to the German regulator, to enable the timer.
