SBC Host Certificate Retrieval via SNMP
When a security certificate is installed locally on the Oracle Communications Session Border Controller , you can poll the expiration of the certificate using the apSecurityCertificateTable.
You can configure the Oracle Communications Session Border Controllerto generate the apSecurityCertExpiredNotification trap once a certificate has expired. The number of minutes between notifications sent is configured in the security-config parameter local-cert-trap-int.
To send a warning of expiration, you can set the security-config parameter local-cert-exp-warn-period to the number of days before the locally installed certificate expires in which you would like a warning.
