Result-Code AVP
If the CLF sends a Result-Code AVP in a UDA message with a value of DIAMETER_UNABLE_TO_COMPLY (5012), the Oracle Communications Session Border Controller forwards the REGISTER message using the default configured location string in the P-Access-Network-Info header. If the configured default string is left blank the Oracle Communications Session Border Controller forwards the SIP REGISTER message without the P-Access-Network-Info header.
