SD-Initiated Keep-Alives Configuration
Use the following procedure to configure SD-initiated Keep-Alives.
In Superuser mode, use the following ACLI command sequence to access SIP Interface configuration mode.
ORACLE# configure terminal ORACLE(configure)# session-router ORACLE(session-router)# sip-interface ORACLE(sip-interface)#
The
options sbc-initiated-keep-alive-name attribute enables SD-initiated Keep-Alive on the current SIP interface and specifies the name of the proprietary Via header parameter used during the SD-initiated Keep-Alive negotiation.
Prefix the command with a plus (+) sign to avoid over-writing existing options configuration.
The following example enables SD-initiated Keep-Alives and identifies the proprietary rkeep header as the header that contains negotiation information.
Endpoints require prior knowledge of this proprietary header name because the SD lacks the capability to relay configuration data to relevant endpoints.ORACLE(sip-interface)# options +sbc-initiated-keep-alive-name=rkeep ORACLE(sip-interface)#
- The option sbc-initiated-keep-alive-interval attribute specifies the frequency of SD-initiated Keep-Alives.
If SD-initiated Keep-Alive is enabled on the current SIP interface (options sbc-initiated-keep-alive-name identifies a proprietary Via header parameter used for Keep-Alive negotiations), use the
options sbc-initiated-keep-alive-interval attribute to specify the default interval between SD-initiated pings.
Allowable values are integers within the range 1 through 999999999 (seconds).
In the absence of an explicit assignment, this attribute defaults to a value of 30 seconds.
This default interval will be used only the proprietary parameter proposed by the endpoint lacks a value.
ORACLE(sip-interface)# options +sbc-initiated-keep-alive-interval=45
- Use done, exit, and verify-config to complete this configuration.
- If necessary, repeat Steps 1 through 5 to configure SD-initiated Keep-Alives on additional SIP interfaces.
