Syslog and Process Logs Configuration
This section describes how to configure syslog and process log servers.
To configure syslogs and process logs:
Syslog Configuration
The Oracle Communications Session Border Controller supports multiple syslog servers. As the number of active syslog increases, the performance level of the Oracle Communications Session Border Controller may decrease. Therefore, we recommend configuring no more than 8 syslog servers.
Set the following parameters to configure syslog servers:
Configure the Process Log Server
Set the following parameters to configure the process log server:
- process-log-level—Set the starting log level all processes running on the system use. Each individual process running on the system has its own process log. The default is NOTICE. Valid values: EMERGENCY | CRITICAL | MAJOR | MINOR | WARNING | NOTICE | INFO | TRACE | DEBUG | DETAIL
- process-log-ip-address—Set the IPv4 address of the process log server. The default value is 0.0.0.0, which causes the system to write log messages to the normal log file.
- process-log-port—Set the port number associated with the process log server. The default value is 0, which causes the system to write log messages to the normal log file. The valid range is: 1025-65535.
