PreviousNextJavaScript must be enabled to correctly display this content
Enabling the Global SIP Configuration for Dynamic Session Agents
To use dynamic session agents for remote S-CSCFs on in-coming service routes, you need to set the create-dynamic-sa parameter in the global SIP configuration to enabled.
To configure the ping mode for a session agent:
In Superuser mode, type configure terminal and press Enter.
If you are adding this support to a pre-existing SIP configuration, you have to select the configuration before you make changes.
create-dynamic-sa—To support the creation of dynamic session agents for remote S-CSCFs on in-coming service routes, change this parameter from disabled (default) to enabled.
