Provisioning SIP Signaling Flows Configuration
To enable correct provisioning of signaling flows upon registration:
  1. In Superuser mode, type configure terminal and press Enter.
    ORACLE# configure terminal
    ORACLE(configure)#
  2. Type media-manager and press Enter.
    ORACLE(configure)# media-manager
    ORACLE(media-manager)#
  3. Type ext-policy-server and press Enter.
    ORACLE(media-manager)# ext-policy-server
    ORACLE(ext-policy-server)#
    If you are adding support for this feature to a pre-existing realm, then you must select (using the ACLI select command) the external policy server that you want to edit.
  4. provision-signaling-flow—Set this to enabled for the Oracle Communications Session Border Controller to send AAR messages to a PCRF on endpoint registrations.
  5. Save and activate your work.
