Asymmetric Dynamic Payload Types Enablement
Transcoding Support for Asymmetric Dynamic Payload Types supports calls with asymmetric payload types such that a codec offered with one payload type and answered with another payload type is acceptable to the Oracle Communications Session Border Controller. This behavior requires transcoding resources.
The Oracle Communications Session Border Controller's default behavior when an endpoint answers an SDP offer with a different payload type than offered is to use what the endpoint replied with as if that were what the Oracle Communications Session Border Controller included in its SDP offer. The Oracle Communications Session Border Controller would then expect to receive the same payload type that the endpoint offered. This is referred to as symmetric payload type mapping, whereby the payload type number is the same for both media flows.
The
Oracle Communications Session Border Controller needs to support the asymmetric case when codecs with
dynamic payload types are used. For example, a call may be set up with the
dynamic codec using one payload type value, and a reINVITE may use a different
payload type value for the same codec. Because of the range of remote UE
equipment's behavior in a reINVITE case, the
Oracle Communications Session Border Controller can support this via its Asymmetric Dynamic Payload
Type feature. That is, some devices do not necessarily use the currently
negotiated payload type, they may use previously negotiated payload types. As
such devices interact with the default
Oracle Communications Session Border Controller behavior, one-way audio may result.
For transcoded calls, enabling this feature places no additional load on the system. But for calls that are not transcoded, this feature consumes transcoding resources.
Configure Transcoding for Asymmetric Dynamic Payload Types
Transcoding support for asymmetric dynamic payload types enables the Oracle Communications Session Border Controller to perform transcoding when the Real-time Transport Protocol (RTP) is offered with one payload type and is answered with another payload type. Enable transcoding for asymmetric dynamic payload types from the command line.
Before You Begin
- Confirm that you are in Superuser mode.
Procedure
