PreviousNextJavaScript must be enabled to correctly display this content
TLS Session Caching Configuration
TLS session caching is global for all TLS functions on your
Oracle Communications Session Border Controller. A new global TLS configuration (tls-global) has been added to the system for this purpose.
To enable global TLS session caching:
In Superuser mode, type
configure terminal and press Enter.
ORACLE# configure terminal
Type
security and press Enter to access the signaling-level configuration elements.
ORACLE(configure)# securityORACLE(security)#
Type
tls-global
and press Enter.
ORACLE(security)# tls-globalORACLE(tls-global)#
session-caching—Set the state for TLS session caching to
enabled if you want to turn this feature on. The default value is
disabled. The valid values are:
enabled | disabled
session-cache-timeout—Enter the time in hours that you want the
Oracle Communications Session Border Controller to cache unique session identifiers so that previously authenticated clients can reconnect. The default value is
12. A value of
0 disables this parameter. The valid range is:
Minimum—0
Maximum—24
If you set this parameter to 0, then cache entries will never age (and not be deleted from the cache unless you use the
clear-cache tls command to delete all entries from the TLS cache). RFC 2246,
The TLS Protocol Version 1.0, recommends that you set this parameter at the maximum, 24.
