Enhanced Control of UDP and TCP Ports
This section explains how to open TCP ports 3000 and 3001 primarily for use with an element manager.
- TCP ports 3000 (used when notify commands are issued remotely, i.e. via an element management system) and 3001 (used for remote configuration, i.e. via an element management system), can be enabled or disabled in the system configuration
This configuration is not RTC enabled, so you must reboot your Oracle Communications Session Border Controller for changes to take effect.
