Enabling EATF Capability
Use the following procedure to enable EATF operations.
Use the following procedure to move to sip-config configuration
mode.
ACMEPACKET# configure terminal ACMEPACKET(configure)# session-router ACMEPACKET(session-router)# sip-config ACMEPACKET(sip-config)#
Use the
eatf-stn-sr parameter to enable EATF operation
and to provide E.164 telephone number of the EATF service.
Provide the E.164 telephone number as either a tel: or a sip: URI. When confirming the E-STN-SR value, the match succeeds based solely on the E.164 portion regardless of the URI type.
ACMEPACKET(sip-config)# eatf-stn-sr tel:+1-237-555-9999 ACMEPACKET(sip-config)#
- Use done and exit to complete configuration.
