AF-Application-Identifier AVP Generation
By default, the Oracle Communications Session Border Controller populates the AF-Application-Identifier AVP with the hostname parameter of the external policy server object that receive's the AAR for the call.
The Oracle Communications Session Border Controller can populate the AF-Application-Identifier AVP with the IMS Communication Service Identifier (ICSI). 3GPP TS 24.173 defines the ICSI format as:
urn:urn-xxx:3gppservice.ims.icsi.mmtel
An ICSI appears in one of the following three SIP headers in an INVITE:
- P-Assured-Service
- P-Preferred-Service
- Accept-Contact
ORACLE(sip-config)# options +get-icsi-from-sip
When the Oracle Communications Session Border Controller has an ICSI value from the access UE and the core, it uses the value received from the core. ICSI values received from the network supercede a configured default ICSI value. When the INVITE is received from the access side, ICSI values are taken from the access side until values are received from the core side. If no valid ICSI value is received in a message, and the Oracle Communications Session Border Controller is not configured with a default-icsi value, the external policy server object’s hostname is used for the ICSI value sent to the PCRF. If an INVITE does not contain SDP, no AAR is generated.
AF-Application-Identifier AVP generation occurs for access and core initiated calls.
AVP Generation on Initial INVITE from UE
The Oracle Communications Session Border Controller receives the UE’s INVITE. When configured to send an AAR on receipt of the INVITE, the AF-Application-Identifier AVP is populated with the contents of one of the following headers (in order of precedence) if present:
- P-Assured-Service (this header is only expected from trusted UEs)
- Accept-Contact
If none of the above three headers are present, the default value of AF-Application-Identifier shall be used.
If the Oracle Communications Session Border Controller is not configured to send an AAR on receipt of an INVITE, the value from the 3 headers will be cached for later AF-Application-Identifier generation.
AVP Generation on response to Initial INVITE from UE
The Oracle Communications Session Border Controller receives the response (1xx or 200 OK) to the original INVITE. When configured to send an AAR on receipt of the response, the AF-Application-Identifier AVP is populated with the contents of one of the following headers (in order of precedence) if present:
- P-Assured-Service
- Accept-Contact header is not expected
Values obtained in this step supercede any value set from the initial INVITE step. If none of the three headers are present, the value determined in the INITIAL invite step is used for the AF-Application-Identifier AVP contents.
AVP generation on reINVITE from UE
The Oracle Communications Session Border Controller can receive a re-INVITEs from the core. The Oracle Communications Session Border Controller populates the AF-Application-Identifier AVP with one of the following headers (in order of precedence) if present:
- Accept-Contact
If none of the three headers are present, the default AF-Application-Identifier value is used.
Responses to the Re-Invites will be treated in the similar manner.
Examples
Example 1:
| Received from access UE | Received from core | Sent to PCRF |
| INVITE with SDP
P-A-S, P-P-S, or A-C header contains “P1” |
N/A | AAR with AF-A-I AVP contains “P1” |
| N/A | 200 OK with SDP
P-A-S, P-P-S, or A-C header contains “P2” |
AAR with AF-A-I AVP contains “P2” |
| re-INVITE with SDP
P-A-S, P-P-S, or A-C header contains “P3” |
N/A | AAR with AF-A-I AVP contains “P2” |
P-A-S, P-P-S, or A-C header contains “P4” |
AAR with AF-A-I AVP contains “P4” |
Example 2:
| INVITE with no SDP | N/A | No AAR generated |
| re-INVITE with SDP
Example 3:
No P-A-S, P-P-S, or A-C headers |
AAR with AF-A-I AVP contains default AF-A-I value. |
| re-INVITE with SDP
N/A | AAR with AF-A-I AVP contains “P3” |
Example 4:
| INVITE with SDP
| N/A | 200 OK with no SDP | AAR with AF-A-I AVP contains “P1” |
| re-INVITE with SDP
Example 5:
| N/A | 183 with SDP
AAR with AF-A-I AVP contains ext-policy-server’s “hostname” |
| PRACK with SDP
| N/A | 200 OK with no SDP | No AAR generated |
| N/A | 200 OK (INVITE) with SDP
Example 6:
| INVITE with SDP
| N/A | re-INVITE with SDP
| 200 OK with SDP
AVP Generation on Initial INVITE from core
The Oracle Communications Session Border Controller receives the original INVITE. When configured to send an AAR on receipt of the INVITE, the AF-Application-Identifier AVP is populated with the contents of one of the following headers (in order of precedence) if present:
- P-Assured-Service
- Accept-Contact
AVP Generation on response to initial INVITE from core
The Oracle Communications Session Border Controller receives the response (1xx or 200 OK) to the original INVITE. When configured to send an AAR on receipt of the response, if none of the three headers (P-Assured-Service, P-Preferred-Service, or Accept-Contact) were present in the original INVITE, the Oracle Communications Session Border Controller populates the AF-Application-Identifier AVP with the contents of one of the following headers (in order of precedence) if present:
AVP generation on reINVITE from core
The Oracle Communications Session Border Controller can receive re-INVITEs from the core. The Oracle Communications Session Border Controller populates the AF-Application-Identifier AVP with one of the following headers (in order of precedence) if present:
- Accept-Contact
Example 1:
| Received from core | Received from access UE | Sent to PCRF |
| INVITE with SDP
| re-INVITE with SDP
Example 2:
| re-INVITE with SDP
Example 3:
AAR with AF-A-I AVP contains ext-policy-server hostname. |
| re-INVITE with SDP
Example 4:
| INVITE with SDP
| re-INVITE with SDP
Example 5:
| N/A | 183 with SDP
| PRACK with SDP
Example 6:
| INVITE with SDP
| 200 OK with SDP
N/A | AAR with AF-A-I AVP contains “P4” |
