Configuring Diameter-based RACF
In the following configuration examples, we assume that your baseline configuration passes SIP traffic, with the Oracle Communications Session Border Controller (OCSBC) in the role of an Access OCSBC. In this example, you perform realm configuration and external bandwidth manager configuration. You also configure media profiles with the bandwidth parameters you reserve at the RACF.
Diameter Support Realm Configuration
To configure the realm configuration for Diameter support in a CAC scenario:
Media Profile Configuration
Values for the following parameters can be found in the PacketCable™ Audio/Video Codecs Specification PKT-SP-CODEC-I06-050812 document.
To configure the media profile configuration for Diameter support in a CAC scenario:
Configuring the Rx Interface for SCTP
You configure the Rx interface for SCTP transport from the ext-policy-server element. See the SCTP Overview and configuration sections in this document's System Configuration chapter for information about SCTP operation and the global settings within the network-parameters element that apply to all SCTP operation.
CAC Debugging
A new argument has been added to the show command for viewing CAC statistics. From the user prompt, type show ext-band-mgr.
ORACLE# show ext-band-mgr 10:11:38-194 EBM Status -- Period -- -------- Lifetime -------- Active High Total Total PerMax High Client Trans 0 0 0 0 0 0 Server Trans 0 0 0 0 0 0 Sockets 1 1 1 1 1 1 Connections 0 0 0 0 0 0 ---- Lifetime ---- Recent Total PerMax Reserve 0 0 0 Modify 0 0 0 Commit 0 0 0 Remove 0 0 0 EBM Requests 0 0 0 EBM Installs 0 0 0 EBM Errors 0 0 0 EBM Rejects 0 0 0 EBM Expires 0 0 0 EBMD Errors 0 0 0
Retrieve the CAC statistics in the log.embd file.
