Max-Requested-Bandwidth-UL & Max-Requested-Bandwidth-DL AVPs
These AVPs reflect RTP bandwidth requirements for a call. The default behavior (i.e., no options are configured) that dictates how these AVPs are created follows.
The average rate limit scenario is when no b=AS: parameter in the SDP and the media-profile, average-rate-limit parameter is configured to a value greater than 0. The Oracle Communications Session Border Controller inserts the media-profile, average-rate-limit parameter ×8 into both Max-Requested-Bandwidth-UL & Max-Requested-Bandwidth-DL AVPs.
The SDP bandwidth scenario is when there is a b=AS: parameter in the SDP and the media-profile configuration element has the following configurations:
- average-rate-limit = 0
- sdp-rate-limit-headroom > 0
- sdp-bandwidth = ENABLED
When these conditions are met, the Max-Requested-Bandwidth-UL & Max-Requested-Bandwidth-DL AVPs are populated with the value in the b=AS: parameter + sdp-rate-limit-headroom ACLI parameter.
