Configuring Interworking
If you have already completed the steps outlined in this chapter’s IWF Service Enhancements section, then enabling the IWF is a simple process. This section shows you how to enable the IWF, and how to enable certain features that you can use to supplement basic IWF functionality.
An IWF configuration might appear like this in the ACLI:
iwf-config
state enabled
media-profiles
PCMU
telephone-event
logging disabled
