Booting an Image
You can either boot your Oracle Communications Session Border Controller from the system’s local storage or from an external device. Both locations can store images from which the system can boot. This section describes both booting methods.
For boot parameters to go into effect, you must reboot your Oracle Communications Session Border Controller. Since a reboot stops all call processing, Oracle recommends performing tasks that call for a reboot during off-peak hours. If your Oracle Communications Session Border Controllers are set up in an HA node, you can perform these tasks on the standby system first.
Boot Parameter Definitions
The system displays all boot parameters when you configure them after a boot interrupt. The system hides some boot parameters from the ACLI so that you do not attempt to configure them. If changed improperly, these parameters can cause the system to sop responding.
The following table defines each of the parameters that the system displays when you perform configuration after a boot interrupt.
| Boot Parameter | Description |
| Boot File | The name and path of the software image you are booting. Include the absolute path for a local boot from the local /boot volume and for a net boot when a path on the FTP server is needed. |
| IP Address | IP address of wancom0. |
| VLAN | VLAN of management network over
which this address is accessed.
Note: VLANs over management interfaces are not supported on the Acme Packet 4600, Acme Packet 3900, and Acme Packet 6xxx. |
| Netmask | Netmask portion of the wancom0 IP Address. |
| Gateway | Network gateway that this wancom0 interface uses. |
| IPv6 address | Version 6 IP address/mask of wancom0. Configure the mask as a forslash (/) after the address followed by the mask in number of bits. |
| IPv6 Gateway | Version 6 network gateway that this wancom0 interface uses. |
| Host IP | IP Address of FTP server from which to download and execute a software image. |
| FTP Username | FTP server username |
| FTP password | FTP server password |
| Flags | Codes that signal the system from where to boot. Also signals the system about which file to use in the booting process. This sequence always starts with 0x (these flags are hexadecimal). |
| Target Name | Name of the
Oracle Communications Session Border Controller as it appears in the system prompt. For example,
ORACLE> or
ORACLE#. You need to
know the target name if you are setting up an HA node.
This name must be unique among Oracle Communications Session Border Controllers in your network. This name can be 63 characters or less. |
| Console Device | Serial output device type, dependent on platform. COM1 applies to virtual serial consoles, VGA to virtual video console. VGA is the default on VMware and KVM. COM1 is the default on OVM . |
| Console Baud Rate | The speed in bits per second which the console port operates at. It operates at 115200 BPS, 8 data bits, no stop bit, parity NONE. |
| Other | Allows miscellaneous and deployment-specific boot settings. |
Booting from Flash Memory
Once you have installed an image, you can boot your Oracle Communications Session Border Controller from its flash memory. With the exception of testing an image before you install it on the flash memory, this is generally the method you use for booting.
To boot from your Oracle Communications Session Border Controller flash memory:
