Local Policy Configuration
To direct a policy attribute to retrieve a next hop from an HSS via an LIR lookup:
In Superuser mode, type
configure terminal and press Enter.
ORACLE# configure terminal
Type
session-router
and press Enter to access the session router path.
ORACLE(configure)# session-router
Type
local-policy
and press Enter. The system prompt changes to let you know that you can begin configuring individual parameters.
ORACLE(session-router)# local-policy -
Choose an existing local-local object with the select command.
ORACLE(local-policy)# select <source-realm>: 1: realms 'realm01'; from *; to * selection: 1
Type
policy-attributes
and press Enter. If you are adding this feature to a pre-existing local policy configuration, you will need to select and edit your local policy.
ORACLE(local-policy))# policy-attributes ORACLE(policy-attributes)#
- next-hop—Set this parameter to cx:name-of-HSS-configuration for this policy attribute to lookup routes by querrying the named HSS via an LIR.
- Type done and save and activate your configuration.
