IP Identification Field Configuration
To enable ID field generation in media-manager:
In Superuser mode, type
			 configure terminal and press Enter.
ORACLE# configure terminal ORACLE(configure)#
Type
			 media-manager
			 and press Enter.
ORACLE(configure)# media-manager ORACLE(media-manager)#
options—Set the options parameter by typing
			 options, a Space, the option name
			 increment-ip-id
			 with a plus sign in front of it, and then press Enter.
ORACLE(media-manager)# options + increment-ip-id
If you type the option without the plus sign, you will overwrite any previously configured options. In order to append the new options to the realm configuration’s options list, you must prepend the new option with a plus sign as shown in the previous example.
 - Save and activate your configuration.
