Fraud Prevention
The Oracle Communications Session Border Controller can constrain outgoing SIP messages to a maximum size in bytes in order to support fraud prevention techniques. If a message does exceed the configured size, it is dropped. A SIP message can be constrained from 0 to 65535 bytes, with a default value of 4096 bytes.
Fraud Prevention Configuration
To set a maximum SIP message size:
  1. In Superuser mode, type configure terminal and press Enter.
    ORACLE# configure terminal
  2. Type session-router and press Enter to access the signaling-level configuration elements.
    ORACLE(configure)# session-router
    ORACLE(session-router)#
  3. Type sip-config and press Enter. The system prompt changes to let you know that you can begin configuring individual parameters.
    ORACLE(session-router)# sip-config
    ORACLE(sip-config)#
  4. Type select to configure the existing sip config.
    ORACLE(sip-config)# select
  5. sip-message-len—Set the size constraint in bytes of a SIP message. The default is 4096. The valid range is:
    • Minimum—0
    • Maximum—65535
      This completes the configuration.
      ORACLE(sip-config)# sip-message-len 5000
  6. Save your work using the ACLI done command.
