Configuring SCTP Support for SIP
RFC 4168, The Stream Control Transfer Protocol (SCTP) as a Transport for the Session Initiation Protocol (SIP), specifies the requirements for SCTP usage as a layer 4 transport for SIP. Use the following steps to:
- configure SCTP as the layer 4 transport for a SIP interface
- create an SCTP-based SIP port
- associate phy-interfaces/network interfaces with SIP realms
- identify adjacent SIP servers that are accessible via SCTP
- set SCTP timers and counters (optional)
Configuring an SCTP SIP Port
SIP ports are created as part of the SIP Interface configuration process.
Configuring the Realm
After configuring a SIP port which identifies primary and secondary multi-homed transport addresses, you identify the network interfaces that support the primary address and secondary addresses to the realm assigned during SIP Interface configuration.
Configuring Session Agents
After configuring the realm, you identify adjacent SIP servers who will be accessed via the SCTP protocol.
Setting SCTP Timers and Counters
Setting SCTP timers and counters is optional. All configurable timers and counters provide default values that conform to recommended values as specified in RFC 4960, Stream Control Transmission Protocol.
Management of Retransmission Timer, section 6.3 of RFC 4960 describes the calculation of a Retransmission Timeout (RTO) by the SCTP process. This calculation involves three SCTP protocol parameters: RTO.Initial, RTO.Min, and RTO.Max. Suggested SCTP Protocol Parameter Values section 15 of RFC 4960 lists recommended values for these parameters.
The following shows the equivalence of recommended values and ACLI defaults.
RTO.Initial = 3 seconds sctp-rto-initial = 3000 ms (default value)
RTO.Min = 1 second sctp-rto-min = 1000 ms (default value)
RTO.Max = 60 seconds sctp-rto-max = 60000 ms (default value)
Path Heartbeat, section 8.3 of RFC 4960 describes the calculation of a Heartbeat Interval by the SCTP process. This calculation involves the current calculated RTO and a single SCTP protocol parameter — HB.Interval.
The following shows the equivalence of recommended the value and ACLI default.
HB.Interval = 30 seconds sctp-hb-interval = 3000 ms (default value)
Acknowledgement on Reception of DATA Chunks, section 6.2 of RFC 4960 describes requirements for the timely processing and acknowledgement of DATA chunks. This section requires that received DATA chunks must be acknowledged within 500 milliseconds, and recommends that DATA chunks should be acknowledged with 200 milliseconds. The interval between DATA chunk reception and acknowledgement is specific by the ACLI sctp-sack-timeout parameter, which provides a default value of 200 milliseconds and a maximum value of 500 milliseconds.
Transmission of DATA Chunks, section 6.1 of RFC 4960 describes requirements for the transmission of DATA chunks. To avoid network congestion the RFC recommends a limitation on the volume of data transmitted at one time. The limitation is expressed in terms of DATA chunks, not in terms of SCTP packets.
The maximum number of DATA chunks that can be transmitted at one time is specified by the ACLI sctp-max-burst parameter, which provides a default value of 4 chunks, the limit recommended by the RFC.
Setting the RTO
An SCTP endpoint uses a retransmission timer to ensure data delivery in the absence of any feedback from its peer. RFC 4960 refers to the timer itself as T3-rtx and to the timer duration as RTO (retransmission timeout).
When an endpoint's peer is multi-homed, the endpoint calculates a separate RTO for each IP address affiliated with the peer. The calculation of RTO in SCTP is similar to the way TCP calculates its retransmission timer. RTO fluctuates over time in response to actual network conditions. To calculate the current RTO, an endpoint maintains two state variables per destination IP address — the SRTT (smoothed round-trip time) variable, and the RTTVAR (round-trip time variation) variable.
Use the following procedure to assign values used in RTO calculation.
Setting the Heartbeat Interval
Both single-homed and multi-homed SCTP endpoints test the reachability of associates by sending periodic HEARTBEAT chunks to UNCONFIRMED or idle transport addresses.
Use the following procedure to assign values used in Heartbeat Interval calculation.
Setting the SACK Delay Timer
An SCTP Selective Acknowledgement (SACK) is sent to the peer endpoint to acknowledge received DATA chunks and to inform the peer endpoint of gaps in the received subsequences of DATA chunks. Section 6.2 of RFC 4960 sets a specific requirement for a SACK Delay timer that specifies the maximum interval between the reception of an SCTP packet containing one or more DATA chunks and the transmission of a SACK to the packet originator.
Use the following procedure to set the SACK Delay timer.
Limiting DATA Bursts
Section 6.1 of RFC 4960 describes the SCTP protocol parameter, Max.Burst, used to limit the number of DATA chunks that are transmitted at one time.
Use the following procedure to assign a value to the SCTP protocol parameter, Max.Burst.
Setting Endpoint Failure Detection
As described in Monitoring, Failure Detection and Recovery, a single-homed SCTP endpoint maintains a count of the total number of consecutive failed (unacknowledged) retransmissions to its peer. Likewise, a multi-homed SCTP endpoint maintains a series of similar, dedicated counts for all of its destination transport addresses. If the value of these counts exceeds the limit indicated by the SCTP protocol parameter Association.Max.Retrans, the endpoint considers the peer unreachable and stops transmitting any additional data to it, causing the association to enter the CLOSED state.
The endpoint resets the counter when (1) a DATA chunk sent to that peer endpoint is acknowledged by a SACK, or (2) a HEARTBEAT ACK is received from the peer endpoint.
Use the following procedure to configure endpoint failure detection.
Setting Path Failure Detection
As described in Monitoring, Failure Detection and Recovery, when its peer endpoint is multi-homed, an SCTP endpoint maintains a count for each of the peer’s destination transport addresses.
Each time the T3-rtx timer expires on any address, or when a HEARTBEAT sent to an idle address is not acknowledged within an RTO, the count for that specific address is incremented. If the value of a specific address count exceeds the SCTP protocol parameter Path.Max.Retrans, the endpoint marks that destination transport address as inactive.
When the primary path is marked inactive (due to excessive retransmissions, for instance), the sender can automatically transmit new packets to an alternate destination address if one exists and is active. If more than one alternate address is active when the primary path is marked inactive, a single transport address is chosen and used as the new destination transport address.
Use the following procedure to configure path failure detection.
Example Configurations
The following ACLI command sequences summarize required SCTP port configuration, and the configuration of required supporting elements.
- PHY interfaces
- Network interfaces
- SIP ports
- realms
- session agents
Sequences show only configuration parameters essential for SCTP operations; other parameters can retain default values, or assigned other values specific to local network requirements.
Phy Interface Configuration
The first ACLI command sequence configures a phy-interface named m10, that will support an SCTP primary address; the second sequence configures a phy-interface named m01 that will support a secondary SCTP address.
ORACLE# configure terminal ORACLE(configure)# system ORACLE(system)# phy-interface ORACLE(phy-interface)# operation-type media ORACLE(phy-interface)# port 0 ORACLE(phy-interface)# slot 1 ORACLE(phy-interface)# name m10 ORACLE(phy-interface)# ... ... ... ORACLE(phy-interface)# ORACLE# configure terminal ORACLE(configure)# system ORACLE(system)# phy-interface ORACLE(phy-interface)# operation-type media ORACLE(phy-interface)# port 1 ORACLE(phy-interface)# slot 0 ORACLE(phy-interface)# name m01 ORACLE(phy-interface)# ... ... ... ORACLE(phy-interface)#
Network Interface Configuration
These ACLI command sequences configure two network-interfaces. The first sequence configures a network-interface named m10, thus associating the network-interface with the phy-interface of the same name. The ACLI ip-address command assigns the IPv4 address 172.16.10.76 to the network-interface. In a similar fashion, the second command sequence associates the m01 network and phy-interfaces, and assigns an IPv4 address of 182.16.10.76.
ORACLE# configure terminal ORACLE(configure)# system ORACLE(system)# network-interface ORACLE(network-interface)# name m10 ORACLE(network-interface)# ip-address 172.16.10.76 ... ... ... ORACLE(network-interface)# ORACLE# configure terminal ORACLE(configure)# system ORACLE(system)# network-interface ORACLE(network-interface)# name m01 ORACLE(network-interface)# ip-address 182.16.10.76 ... ... ... ORACLE(network-interface)#
SIP Port Configuration
This ACLI command sequence configures a SIP port for SCTP operations. It specifies the use of SCTP as the transport layer protocol, and assigns the existing network interface address, 172.16.10.76, as the SCTP primary address. Additionally, it identifies three other existing network addresses (182.16.10.76, 192.16.10.76, and 196.15.32.108) as SCTP secondary addresses.
ORACLE# configure terminal ORACLE(configure)# session-router ORACLE(session-router)# sip-interface ORACLE(sip-interface)# sip-ports ORACLE(sip-port)# address 172.16.10.76 ORACLE(sip-port)# transport-protocol sctp ORACLE(sip-port)# multi-homed-addrs (182.16.10.76 192.16.10.76 196.15.32.108) ... ... ... ORACLE(sip-port)#
Realm Configuration
These ACLI command sequences configure a realm for SCTP operations. The first ACLI sequence assigns a named realm, in this example core-172, to a SIP interface during the interface configuration process. The second sequence accesses the target realm and uses the network-interfaces command to associate the named SCTP network interfaces with the realm.
ORACLE# configure terminal ORACLE(configure)# session-router ORACLE(session-router)# sip-interface ORACLE(sip-interface)# realm-id core-172 ... ... ... ORACLE(sip-interface)# ORACLE# configure terminal ORACLE(configure)# media-manager ORACLE(media-manager)# realm-config ORACLE(realm-config)# select identifier: core-172 1. core-172 ... selection: 1 ORACLE(realm-config)# network-interfaces (m01 m10 ...) ... ... ... ORACLE(ream-config)#
Session Agent Configuration
The final ACLI command sequence enables an SCTP-based transport connection between the Oracle Communications Session Border Controller and an adjacent network element.
ORACLE# configure terminal ORACLE(configure)# session-router ORACLE(session-router)# session-agent ORACLE(session-agent)# select <hostname>: core-172S1 1. core-172S1 ... selection: 1 ORACLE(session-agent)# ORACLE(session-agent)# transport-method staticSCTP ORACLE(session-agent)# reuse-connections none ... ... ... ORACLE(session-agent)#
