PreviousNextJavaScript must be enabled to correctly display this content
ACLI Configuration
You must configure a transcoding realm and transcoding agents on your Access Session Border Controller (A-SBC), when used in a pooled transcoding deployment model. Set the parameters as part of the global SIP configuration.
If you are adding transcoding support to a pre-existing SIP configuration, you must select the configuration before you can make changes.
Enter the name of a configured realm designated as the separate realm for the public SIP interface for exclusive communication with the Transcoding Session Border Controller (T-SBC) in as pooled transcoding deployment.
transcoding-agents—Enter any IP address, IP address and port combination, session agent hostname, or SAG name to use as a transcoding agent. You can make multiple entries in any combination of these values. For example, you might list an IPv6 address and port, a session agent, and a SAG.
To make multiple entries in the list using in one command line, enclose the entire list of value in parentheses ( ( ) ), separating each with a Space as in the example below.
To add a transcoding agent to an existing list, put a plus sign before the value you want to add, e.g. +154.124.2.8.
To remove a transcoding agent from an existing list, put a minus sign before the value you want to remove, e.g. -154.124.2.8.
