Global H.323 Settings
When you configure H.323 signaling for your Oracle Communications Session Border Controller, you set global and per-interface parameters. The global parameters govern how the Oracle Communications Session Border Controller carries out general H.323 operations, and these settings are applied to all interfaces you configure for H.323 use. For example, you can turn H.323 support on and off for the entire Oracle Communications Session Border Controller using these settings.
Global H.232 Settings Configuration
For the ACLI, global H.323 parameters are:
state State of the H.323 protocol log-level Log level for H.323 stacks response-tmo maximum waiting time in sec for response to a SETUP message connect-tmo maximum waiting time in sec for establishment of a call options optional features/parameters
