Overview
The network interface element specifies a logical network interface. In order to use a network port on a network interface, you must configure both the phy-interface and the corresponding network interface configuration elements. If the network interface does not use VLANs tagging, ensure that the sub-port-id parameter is set to 0, the default value. When VLAN tags are used on a network interface, the valid sub-port-id value can range from 1-4096. The combination of the name parameter and the sub-port-id parameter must be unique in order to identify a discrete network interface.
