If you are adding support for this feature to a pre-existing SIP configuration, then you must select (using the ACLI
select command) the configuration that you want to edit.
untrusted-conn-timeout—Enter the time in seconds that you want the
Oracle Communications Session Border Controller to keep TCP and TLS connections open for untrusted endpoints. The default value is
0, which will not start the timer. The valid range is:
