4096-bit RSA Key Support
The Oracle Communications Session Border Controller (OCSBC) supports 4096-bit RSA keys for SIP Transport Layer Security (TLS) on all platforms. The 4096-bit support enables you to import root certificates for SIP communications secured with TLS into the OCSBC.
Use the key-size parameter in the certificate-record configuration to set the key size.
