Diameter CLF/e2 Error Bypass
When a CLF returns error messages i.e., any other Diameter answer than DIAMETER_SUCCESS, you can configure the Oracle Communications Session Border Controller to override the default behavior and still forward REGISTER messages with P-Asserted-Network-Id header containing the default-location-string parameter value. If the default-location-string parameter value is empty, the REGISTER message is forwarded without the P-Access-Network-Info header. This error bypass feature is configured by setting the permit-on-reject parameter to enabled for an external policy server configuration element with application-mode set to e2.
