IPv6 Support for Management and Telemetry
Several management-oriented parameters on the Oracle Communications Session Border Controller may be configured with IPv6 addresses to be used within IPv6 networks.
The following parameters that are configured with IP addresses accept IPv6 addresses to be used within IPv6 address space.
You may configure the wancom0/eth0 physical interface in the bootparams with an IPv6 address and complementary IPv6 gateway via the following parameters:
  • bootparams, inet on ethernet
  • bootparams, gateway inet
You may configure a syslog server with an IPv6 destination address via the following parameter:
  • system, system-config, syslog-servers, address
You may configure a system access list entry with an IPv6 source address and complementary IPv6 gateway.
  • system, system-access-list, source-address
  • system, system-access-list, netmask
You may configure a RADIUS server with an IPv6 destination address via the following parameter:
  • security, authentication, radius-servers, address
