To configure the
Oracle Communications Session Border Controller to perform Session-Agent DNS-SRV load balancing:
From superuser mode, use the following command sequence to access sip-config configuration mode. While in this mode, you configure SAG-based address resolution.
Use the
ping-all-addresses parameter to enable Session-Agent DNS-SRV load balancing.
Use
done,
exit, and
verify-config to complete Session-Agent DNS-SRV load balancing configuration.
The
show sip agents
ACLI command displays the availability of dynamically resolved IP addresses
ORACLE# show sip agents acme.engr.com
21:46:05-51-router
Session Agent acme.engr.com(core) [In Service] NO ACTIVITY
... Statistics of ALL IPs associated with this SA ....
Destination: 192.168.200.235 In Service
Destination: 192.168.200.231 In Service
