PreviousNextJavaScript must be enabled to correctly display this content
Enabling Restoration Procedures
Use the following
procedure to enable compliance with IMS Restoration Procedures mandated by 3GPP
TS 23.380 and TS 24.229. You can enable compliant behavior on individual SIP
interfaces. By default, TS 23.30/TS 24.229 compliance is disabled on all SIP
interfaces.
From superuser mode, enter the following ACLI command sequence to
access sip-interface configuration mode.
Use the select ACLI command to select the target SIP interface,
that is the SIP interface to be brought into compliance with TS 23.30/TS 24.229
requirements.
Use the pcscf-restoration ACLI parameter to enable TS 23.30/TS
24.229 compliance.
Enable compliance by assigning a string value to this parameter.
The string provides the contents of the <reason> element.
ACMEPACKET(sip-interface)# pcscf-restoration “Restoration procedures in force”
Use
done and
exit to complete enabling restoration
procedures on the current SIP interface.
As required, repeat steps 1 through 4 to enable Restoration
Procedures on other SIP interfaces.
