System Wide MTU Size
To change system wide MTU settings:
Access the
system-config configuration element.
ORACLE# configure terminal ORACLE(configure)# system ORACLE(system)# system-config ORACLE(system-config)#
Type
select to begin editing the
system-config object.
ORACLE(system-config)# select ORACLE(system-config)# -
ipv6-signaling-mtu or
ipv4-signaling-mtu Configure MTU in the system config and optionally in the network interface. Default will be 1500 bytes.
ORACLE(system-config)# ipv6-signaling-mtu 1500 ORACLE(system-config)# ipv4-signaling-mtu 1600
- Type done to save your configuration.
