ATCF INVITE ICSI Matching Configuration
You can configure the Oracle Communications Session Border Controller to check, on reception of an INVITE on an ingress sip-interface that has a configured ATCF and before applying any of the already implemented logic, whether the incoming INVITE includes the ICSI (Instantaneous Channel-State Information) of the requested service and, if so, to involve the ATCF in the call flow.
  1. Access the sip-interface configuration element.
    ORACLE# configure terminal
    ORACLE(configure)# session-router
    ORACLE(session-router)# sip-interface
    ORACLE(sip-interface)#
  2. Select the sip-interface object to edit.
    ORACLE(sip-interface)# select
    <RealmID>:
    1: realm01 172.172.30.31:5060
    selection: 1
  3. atcf-icsi-match — enter the ICSI string you want to match.
  4. Type done to save your configuration.
