Generate an RTCP Receiver Report
When you want to generate a Real-Time Transport Control Protocol (RTCP) Receiver Report separately from the default Sender-Receiver Report (RFC 3550), for example to encapsulate the receiver statistics differently, add the
xcode-gratuitous-rtcp-report-generation option in the media-manager configuration. After you add the option and reboot the system, the
OCSBC runs RTCP Receiver Reports for all media sessions that generate RTCP from DSPs.
When you add the
xcode-gratuitous-rtcp-report-generation option, be sure to type the
+ character before the option. The
+ character appends the new option to the realm configuration's options list. Without the + character, the system overwrites any previously configured options.
