SNMP DNS ALG Statistics and Traps
The AP-DNSALG-MIB is defined to provide standard-compliant object definitions and descriptions for the SNMP information provided by Oracle Communications Session Border Controller for dns-alg query related information. This MIB corresponds to the related ACLI show commands.
By setting the trap-on-status-change parameter in the dns-config to enabled, the following traps become active on the system:
| Traps | Description |
apDnsAlgStatusChangeTrap apDnsAlgStatusChangeClearTrap |
This trap is set and clears when any DNS-config object changes its operating status. |
apDnsAlgConstraintStateChangeTrap apDnsAlgConstraintStateChangeClearTrap |
This trap is set and clears when any dns-config object enters constraints exceeded state. |
apDnsAlgSvrConstraintStateChangeTrap apDnsAlgSvrConstraintStateChangeClearTrap |
This trap is set and clears when any single DNS server enters constraints exceeded state. |
Refer to the MIB ZIP archive to view the AP-DNSALG-MIB MIB file.
