Media Release between Endpoints with the Same IP Address
You can configure your Oracle Communications Session Border Controller to release media between two endpoints even when one of them:
- Is directly addressable at the same IP address as a NAT device, but is not behind a NAT device
- Is at the same IP address of a NAT device the other endpoint is behind
You enable this feature on a per-realm basis by setting an option in the realm configuration.
When this option is not set, theOracle Communications Session Border Controller will (when configured to do so) release media between two endpoints sharing one NAT IP address in the same realm or network.
Media Release Configuration
In order for this feature to work properly, the following conditions apply for the realm configuration:
- Either the mm-in-realm or the mm-in-network parameter must be disabled; you can have one of these enabled as long as the other is not. The new option will apply to the parameter that is disabled.
- If either the mm-in-realm or mm-in-network parameter is enabled, then the mm-same-ip parameter must be disabled.
To enable media release between endpoints with the same IP address:
