SD Incorrectly Appends Cookie in SIP REGISTER Message
The Oracle Communications Session Border Controller does not recognize a SIP URI containing tel-URI information if it doesn’t also contain a "user=phone" parameter. This behavior adversely affects creation of the acme_nat tag and placement of the cookie
You can enable the option proces-implicit-tel-URI to recognize an implicit tel-URI and places the cookie in the correct location.
